Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Bill Hanlon, Otto Skorzeny, Gdads51, Cosmo, MickeyP), 59 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#960830 08/03/2013 5:18 AM
i rebuilt my speedo new face and needle now when im driving and get up to 50mph and hold steady my speedometer wants to keep climbing. any one know what would cause this.
johns truck #960867 08/03/2013 10:22 AM
does it just 'keep climbing' for seconds, or does it never stop?
how fast is it climbing? moving steady or jumping?
how do you know you're actually 'holding steady' and not accelerating slightly?
how do you know you're doing 50?
I'd guess there's something binding so that the mechanism is struggling to get to where the magnet wants it to, or you messed up the hair-spring that controls the spin
johns truck #960960 08/03/2013 4:31 PM
dont know if im going exactly 50 but i am holding a pretty steady speed.it steady moving up and keeps climbing till i let off when im driving about 50 it climbs up to 70 or 80 and i know im not going that fast. could it be because it hasnt been used in years.
johns truck #960964 08/03/2013 4:54 PM
certainly, they're usually full of crud after 50 years, but if the needle goes to 80 when you're actually doing 50, the dirt would just be causing the slowness, some damage is making it inaccurate, the mechanism can't spin faster than the cable tells it to, so it's the reading that's the real problem - when you replaced the needle is the most likely cause, did you get the needle on correctly? any struggle there? have you checked the tech tip about the AD speedo? the mechanism is delicate, there's a fine coil spring that "fights" the movement caused by the spinning magnet, keeping the needle moving steady and balancing the magnets torque when it gets to the right speed, the spring is critical to accuracy .... any time you find a problem after working on anything, the first suspect is something you did wink
johns truck #960966 08/03/2013 5:16 PM
try using a GPS to check you're speed and then you'll know where you're needle should be
johns truck #960981 08/03/2013 6:59 PM
needle came off and went back on with no problem easy off easy on. if it is the spring can it be fixed.
johns truck #960990 08/03/2013 8:10 PM
you'd be best to replace the whole chunk with the needle shaft on it, unlikely you'd be able to properly recoil the spring to the exact right tension .... first thing is to open up the speedo as shown in the tip and investigate
