0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | How do I remove the shaft from the steering column on a 41 chevy truck? I'm customizing, so I have eliminated the box already. Whats with the upper bearing and how does the shaft slide out? Thanks in advance! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pry the upper bearing out, it has a tiny lip that just laps the top of the tube, catch it with a thin screwdriver or stiff putty knife and tap up, working around the tube .... unless you cut the column at the box, I don't think the shaft comes out, part of box
Bill | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | The shaft and box are one piece, how have you removed the box and not the shaft?
If you are talking about the outer tube, it is bolted to the bottom of the dash with a u-clamp and special holder plus there might be a clamp at the floor board.
If you really want the shaft out of the gear box, read this manual,http://chevy.oldcarmanualproject.com/booklets/52mts20/5220mts01.htm
Once you have the tube out of the cab, use a broom handle or the steering shaft to knock the bushing out the top of the tube.
Its best not to destroy the gear box, guys like us with the older trucks use your modern gear box to replace our old style ones.
Joe | | |
