| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Hello fellow Bolters
I am trying to find the off white paint formula for the bumper on a 53 1/2 ton chevy truck. I assume it is the same color as the grill back slats which I have painted many years ago ... but we can not locate the formula.
Thanks in Advance! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The GM 1953 Tech Specs Manual indicates that the inner grill bars in 1953 were Thistle Gray (as were hub caps) and the bumper was Anvil Gray. Check the 47-55 colors Tech Tip. There are instructions for contacting PPG - they had "offset formulae" for me when I contacted them a little over 10 years ago. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And if PPG can give you a formula for Thistle Gray and Anvil Gray, please post it for the rest of us.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | | | |
