1 members (TexasA&M48Truck),
190
Mod | | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 28 | My 1950 1/2 ton has a three speed manual transmission attached to the original 216 engine. How do you confirm the fluid level in the case. Is there a bolt to remove and check the level the same as the rear end. Sorry if this is a dumb question. I could not get much of anything on the search function.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | danv, If you have an original type of 3-speed transmission, there is a hole plug about 1/2 way up the passenger side of the transmission case. That is the fill hole (and it marks/sets the warmed-up-gear-oil fill-level). http://chevy.oldcarmanualproject.com/chevyowner/51tom78.htm | | | | | Joined: Aug 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 28 | Thanks for the quick reply. Dan V | | |
