4 members (Oswald, GRNHydra, Napco Man, Greg_H), 98 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#96064 06/23/2006 7:39 AM
I have a grain truck. '48 and I want to modify the lights so I have kind of a sequential thing where first the turn signal lights go off and then the marker lights at the corners of the bed. Any direction where I can go to get the data to make it happen. Tail lights are undecided as yet.....may go original, or may go with '64 ford lights in the bed, or maybe 40 ford Chevrons. I know years ago, JC Whitney sold a thing to make turn signals sequential but that was 30 years ago (when they used to have a show)
there is an electronic version used in new mustangs,, not sure how to retro it tho,,my 67 cougar had an electric motor w/3 sets of points riding on a small cam, the cam let each set of points close in sequence-it was pretty neat,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
My buddy had a '71 Cougar with sequentials. They make use of a box (6" x 10" x 2"?) that mounts in the trunk. Wires go in, wires go out, lights work sequentially.
Like the late 60s Cougars, the Shelby Mustangs also had sequentials. You might not want brand F on your 'bolt, but there are probably plenty of replacement boxes for those models and could easily be used for your application. Off the top of my head, I'd try Larry's Mustang.
Ex Hall Monitor
Ex Hall Monitor
If you're converting to 12v this might help: http://www.webelectricproducts.com/
Scroll down to new products.
Take a look around this web site
LED
You would probably need some timer relays and lots of wiring.
But this turn signal on the web site is what im going to do eventually.
Riding in the Passing Lane
Some chevy trucks in the 70,s had a system like I think you are referring to on the front. They used an insulated marker light on the side & the turn sinal grounded through it. When the turn light went out the marker light came on & they alternated.
1972 Chevy c10 Cheyenne Super
