4 members (Shardean, Peggy M, klhansen, Eisenholtz), 50 guests, and 5 robots.
Topics128,022
Posts1,055,376
Members48,420
#960667 08/02/2013 9:28 AM
My 1950 1/2 ton has a three speed manual transmission attached to the original 216 engine. How do you confirm the fluid level in the case. Is there a bolt to remove and check the level the same as the rear end. Sorry if this is a dumb question. I could not get much of anything on the search function.
danv,
If you have an original type of 3-speed transmission, there is a hole plug about 1/2 way up the passenger side of the transmission case. That is the fill hole (and it marks/sets the warmed-up-gear-oil fill-level).
http://chevy.oldcarmanualproject.com/chevyowner/51tom78.htm
Thanks for the quick reply. Dan V
