4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
Ex Hall Monitor
Ex Hall Monitor
Sir Searchalot
Sir Searchalot
Thanks Tiny.
Thanks, that really was a good little film.
I'm still puzzled by the function of the oil distributor valve. From the sound of it and the drawings I've seen I think it regulates the oil pressure going to different passages -- up to the valves vs. down to the nozzle galley perhaps? Why is such a valve needed in the first place?
Pete P.
Harborcreek, Penna.
Ex Hall Monitor
Ex Hall Monitor
I'm not an expert by any means but I believe it was to make sure the main bearings had adequate pressure before allowing oil to divert to the rockers. If I'm wrong someone will point that out. grin
