1 members (baldeagle), 100 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
Hi Folks,
Thia may sound dumb but I think I've forgotten how the heater controls work.
Starting from the top the lever says FAN and slides horizontally. I think LO speed is to the left and HI is all the was to the right.
Next down is INSIDE AIR and OUTSIDE AIR. All the way left is inside and all the way to the right is outside.
Beneath these two sliders are two controls that slide vertically. To the left is TEMP and on the right is DEFROST.
Am I correct in thinking that when the left (TEMP) slider is all the way down there is more heat?
When the right slider (DEFROST) is all the way down that gives me more defrost depending on how far down I slide it?
Many Thanks for your help.
yes, correct
Sepp, I don't know what you're planning but I used a stock 56 heater and hooked it up to the heater control unit. I don't have the fancy stuff to make it function like it should so it's basically just an on/off switch and defrost.... but it looks cool.
Larry Bear
55.5 Chevy 3100 Panel
Moderated by  ndkid275, Phak1
