2 members (TUTS 59, Maybellene),
157
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | The brake pedal on my 55 Task Force is not in line with the clutch pedal. The clutch pedal is horizontal. The brake pedal is turned down approx. 30° at the right edge. I took the nut off and tried to turn it but it wouldn't budge. Is it splined into the lower pedal? Do I need a bigger hammer or a puller? The pedals are not bent. The brake pedal is just turned a bit. Thanks for any and all suggestions! | | |
