1 members (Hotrod Lincoln),
136
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 |
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2012 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 28 | Thanks, that really was a good little film.
I'm still puzzled by the function of the oil distributor valve. From the sound of it and the drawings I've seen I think it regulates the oil pressure going to different passages -- up to the valves vs. down to the nozzle galley perhaps? Why is such a valve needed in the first place?
Pete P. Harborcreek, Penna.
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I'm not an expert by any means but I believe it was to make sure the main bearings had adequate pressure before allowing oil to divert to the rockers. If I'm wrong someone will point that out.
