2 members (78buckshot, 1 invisible),
390
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 48 | Hi All, After three days of penetrating oil and elbow grease, the two bolts for the master cylinder are not budging. I was able to remove the hydraulic line and the armature/rod cotter and pin. Is there anything apecial I need to know about the MC mounting bolts? I assume the nut on the backside of the bracket is welded to the bracket? Is this mounting bolt only threaded to the bracket nut or are there threads through the MC assembly? Is it ok to apply brute force to these bolts to get them to release? MC Mounting Bolts MC Mounting Bolt Bracket Nut Thanks! jose | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Mine was not really a nut, more so a steel plate with 2 tapped holes. It was not welded to the frame.
I was able to get it the break loose by putting a pipe on a 1/2" drive ratchet.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Correct, the "nut" is a rectangular bar with tapped holes for both bolts. Some penetrating oil and lots of torque is you best bet. Even if you break off a bolt or two you'll be OK in the end, they and the nut plate can be replaced. If it comes to it, with the nut plate out you can probably remove the broken bolts. | | |
