1 members (baldeagle),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | Hey all.
I came across a problem today and that would be that my carb. leaks like a sieve! And I am at a lost on this one
Some background. The carb. In question is on my 61 Chevy c-10 stock motor and brand new carb. (Rebuilt single barrel rochester) and new fuel pump(manual with electric wipers) I also have it running on a external fuel tank(small 1gal. Container with a fuel hose and filter running to the pump)
The problem, after starting up the truck the carb starts to leak from around the throttle linkage(and not a small drip or too, it's a fast leak!) so my thoughts are that it's getting to much fuel in the cup and over flowing? Is that possible? If I shut off the fuel the engine keeps running( I am guessing from the fuel in the lines/ carb. Cup) engine runs, starts to run faster then begins to die so I turn the fuel back on and the leak starts again.
Any help on this would be really really great! I can post a video if that helps too
Thanks again -Tim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim,
Did you rebuild the carb?
It sounds like the float level setting is wrong.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The only way it can do this is fuel getting by the needle & seat. It can be caused by dirt in the seat, a bad float, or as TC says an improperly set float level, or too much fuel pressure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | Hey guys that's for the reply.
I did not rebuild it myself, I got it of rock auto.com. Is said that it came pre adjusted but I am sure in shipping it could become un-adjusted. Also with dirt I always run it with a paper filter so if dirt is getting by is there a better filter I can use?
I am guessing the plan of action would be pull apart, clean, adjust and if problem continues buy a regulator of some kind? Also I have tried looking around but can't find the listing of the fuel PSI for this truck, anyone know what it runs around? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1961 235/261 fuel pump was rated at 3.5-4.5 psi. I think that 3-7psi would work fine without a pressure regulator - let's see what others say. | | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | Update;
After pulling the carb. And cleaning, and adjusting ( was within factory specs) I reset the float level a little higher. After re-instal it was still leaking so I put on a pressure regulator and set it for 3.5 psi and seems to be running fine with no more leaks and took her for a drive today. Only thing going on now is a slight rough idle and if you hit the brakes hard she dies.
Thanks all for the help | | | | | Joined: Sep 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 28 | Like your freshman science teacher taught you, isolate only one variable at a time.
I think the the pressure regulator was unnecessary but it didn't hurt. More than likely your float was set right from the factory but had some dirt in the needle/seat or it was stuck open. The problem you're having now is that your float level is too low and when you hit the brakes hard the gas is sloshing to the front of the carburetor bowl and starving the engine of fuel. Try taking it back apart and setting the float level to factory specs and see if that helps.
I have the adjustment data table right in front of me at the moment. Your float level should be 1-9/32" which is measured from the gasket surface to the bottom of the float in the "closed" position. In the "open" position it should hang down 1-3/4"
Hope this helps amd let us know how ya make out
1963 Chevy C30 - 292 I6 +.040" 10.78:1, SM465 1978 GMC K2500
"Four gears with a granny low and six cylinders straight in a row."
| | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | Sounds like a plan, I'll be working on that this weekend after I get a new battery(mine was stolen right from the truck!) I will post a update on how it goes
Thanks again for all the help! | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Also, carry a fire extinguisher.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Using TC's info: anything over 4.5psi is absolutely a NO NO. Agree with reset float, AND the drop, to specs. As has been said by several, carbs leak there for several reasons: Over flow from bowl, too much pressure, float leaking/sinking. Hope your "new" fuel pump is not an electric you forgot to tell us about. The correct stock mechanical pump would not need a regulator. I actually have never heard of a regulator on a carb engine with mechanical fuel pump.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
