| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Got starter reworked, good battery, won't start, slow roll from the starter. Only has ground strap from battery to tranny. was told need more ground straps. Yes? and Where? Got any picts?
Mark
6v - Generator - 216 1.5ton
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mark Miller, there are many possible reasons for slow cranking, the starters electrical circuit is only one of them. That being said, it sounds like you have a good basic circuit. Are all your connections clean and tight, are your cables the proper size for the voltage you are working with, six volt cables are twice as large as the twelve volt ones you find in the auto parts stores. In addition to the ground from the battery to the transmission, there should be a large ground connection to the frame (chassis), and other smaller ground wires to the cab, and front fenders, and the box or bed or deck. You can't have too many ground wires, hope that helps. | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | today I replaced the ground strap from the battery to the transmission. I added a ground wire (4g) from the battery neg terminal to the frame and another (4g) from the starter to the frame. Still slow crank. I pulled the starter and will take back to the place that just did the rebuild. I heard today that you could use a 9v battery and get better results. ?????
Mark
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 8V not 9, but forget that, "better results" can be had with 6V in a good system, 4 gauge is 12V wire, 6V should be 1 ga or heavier, using 0 or 00 is really best, and make totally sure every place you connect ground cables to is clean shiny metal, and it's best to use an external tooth star washer on them, make it dig in so there's zero resistance at the connections
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just a note: It's hard to tell if you have a "good battery" unless you had it tested by a good load tester. If you are saying it shows 12.4V on a volt meter, that is not telling if it breaks down. Use another Bat to try if you can. Be real sure it's a "good battery" before continuing.... and proper size cables as mentioned.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | took the starter back to the shop, he had overlooked and there was a short inside. Fixed and put on, changed the extra ground from 4G to 0. Replace the old started cable as well. Bang, running great.
Now I need to work on the slop in the steering.
What forum next?
Thanks guys,
Mark
