| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Are these for alignment only? I found a flywheel with two openings, the crank has three dowels. Can I just use two, and do I need to fill the third hole if I do? Why did they add more as the years went on?
Thanks! Tom | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chev used 3 dowels starting in 1940 and continued using 3 up to 1962(1963 for 261). After that they went to one and in a lot of cases none. The 3 dowels and bolt holes are unevenly spaced so the flywheel will only go on in one position. If you have a flywheel with only 2 holes for dowels it will most likely not fit.
See the USA in your vintage Chevrolet! My Blog | | |
