| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95952 06/15/2006 7:05 AM | Joined: Jan 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 23 | Jim Carter sells a tail light changeover bracket. Part No. LG290. It lets you put a 21 cp bulb in for the brake light. What they fail to say is what bulb to buy. I am going 12 volt and I just happen to have a set of original tail lights on a 2 ton and I am wondering what bulbs should I get with this modification | | |
#95953 06/15/2006 5:01 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You've got a couple of choices... you could get standard bulbs or LED. The socket Carter sells for dual filiment bulbs is pretty standard you could take it to an autoparts store and match it up with either the standard or LED style. If the FLAPS doesn't have LED try a truck stop.
#95954 06/15/2006 5:48 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | 1157 will work for a 12v application.
1154 will work for a 6v application.
LEDs are available in a "Double Poled" variety for this sort of thing. | | |
