| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | My oil pan, jets arm and wire U pins came back from the machine shop in bags, now I need to put it back together. On those U pins (not sure exactly what they are called) it appears they could go several different ways. I do not have a good 'before' picture to show me. Can anyone direct me on how to place those U pins? If the pin goes on top or below the jet? If the curved portion of the U goes towards the jet end or up against the side of the pan? A picture or diagram would greatly help, if one is available. (I've tried searching with no luck). Thanks in advance. Kevin - '51 3/4 t. Chevy | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | After you put them back in you should check the alignment of the nozzles. As you can see in THIS LINK there is a gauge for checking the alignment. You can also see in the picture that the water jet is hitting in the center of a 1"(aprox)square spot on the pan after it goes through the hole in the target gauge. I have for years checked alignment by just making sure the jet hits in the center of that 1" square spot without using the gauge.
See the USA in your vintage Chevrolet! My Blog | | |
