2 members (kades51, DaveV),
151
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hello everyone, well my radiator needs to be replaced, has anyone found a good replacement for a 55 second series truck? I am looking for a direct fit. I saw some postings on here with people having fan blade issues being to close to their new radiator, dont want to run into any of those issues. If any of you have found one can you tell me where you bought from and part number? Thanks in advance. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you have a radiator shop near you, they should be able to recore/repair the original, usually for far less than a new replacement that may or may not fit.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, had good luck with this. Direct fit. Good seller, Good price. Look up item no. 230623476096 on Ebay.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Looked up the listing, it says made for direct fit for v-8 engines, 6 cylinder engines may require fabrication. Did you use it on a six cylinder? If so any problems? Thanks. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I used it on a truck that had a later model V8 put in. See how much room you have between mounting flange and fan blade, then email and ask what that dimension is on that radiator. 6 Cyl engine is longer. I assume you have a 6.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Matt, the 55-59 radiators are all identical, 6 or 8, the listing says it's the same as the 'heavy duty' rad, which they assume was for the V8, but could have been optioned in a 6 cyl - the difference between the 6 and V8 is where the core supports were mounted, in 55-57 they moved the rad back for the V8 because the engine is shorter, but all the difference was in position and sheet metal shrouding, the core support was the same piece - in 58/9 on a V8 they supplied a shroud to make up for the length difference, rad stayed forward for both 6 and 8
but as longbox said, check a local rad shop, if the tanks are not rotten yours can be recored cheaper, much better choice if it's possible in your area
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You may find what I found, nobody does recores anymore around here. They want to sell you a new one. All they know is plastic. No Solder Jockey's left. No downflow left.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Exactly what I found, they told me they don't recore those anymore. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same thing here in Northern Illinois, all of the old radiator shops have closed up and any one calling them selves a radiator shop just is an installer for new plastic or aluminum radiators. I've used U.S. Radiator several times with good luck. http://www.usradiator.com/chevrolet-truck-1955-59-all-mt-radiator.html Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | There's tons of those alum rad's on flea bay to fit almost anything. They are cheap and may or may not last long. Check Classic Parts and Jim's Carter's Truck Parts. They both sell brass/copper US made radiators but may well be back ordered.
FWIW, I'm going with an elec fan with a shroud which should help big time. That plus a new Rad should be good. I did find a shop in Auburn Ca that would recore for $500+... never mind... | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thanks for all the advice, I really appreciate it. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | not to highjack the thread, but are the big bolt radiators bigger? i know the whole front end is bigger but not sure about the radiator.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the height/width wouldn't be different mater, but the thickness varied, there was a 'standard' radiator and a 'heavy duty'
Bill | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | so if i got a pickup radiator it would fit, but i would have to probably get a different fan shroud? Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not necessarily, the shroud should fit, won't be a large difference in thickness, at most it will have a slight gap that could be easily dealt with by something like a fan spacer
Bill | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | alright, thanks for answering that, i passed up a recored radiator for 50 bucks this spring because i wasn't sure
