Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible), 126 guests, and 3 robots.
Topics128,283
Posts1,058,513
Members48,490
#958918 07/25/2013 5:49 PM
Hello everyone, well my radiator needs to be replaced, has anyone found a good replacement for a 55 second series truck? I am looking for a direct fit. I saw some postings on here with people having fan blade issues being to close to their new radiator, dont want to run into any of those issues. If any of you have found one can you tell me where you bought from and part number? Thanks in advance.
matt55 #958946 07/25/2013 7:30 PM
If you have a radiator shop near you, they should be able to recore/repair the original, usually for far less than a new replacement that may or may not fit.
Bill Burmeister
matt55 #958950 07/25/2013 7:48 PM
Sir Searchalot
Sir Searchalot
Yes, had good luck with this. Direct fit. Good seller, Good price. Look up item no. 230623476096
on Ebay.
matt55 #958960 07/25/2013 8:18 PM
Looked up the listing, it says made for direct fit for v-8 engines, 6 cylinder engines may require fabrication. Did you use it on a six cylinder? If so any problems? Thanks.
matt55 #958984 07/25/2013 9:37 PM
Sir Searchalot
Sir Searchalot
I used it on a truck that had a later model V8 put in. See how much room you have between mounting flange and fan blade, then email and ask what that dimension is on that radiator. 6 Cyl engine is longer. I assume you have a 6.
matt55 #958986 07/25/2013 9:38 PM
Matt, the 55-59 radiators are all identical, 6 or 8, the listing says it's the same as the 'heavy duty' rad, which they assume was for the V8, but could have been optioned in a 6 cyl - the difference between the 6 and V8 is where the core supports were mounted, in 55-57 they moved the rad back for the V8 because the engine is shorter, but all the difference was in position and sheet metal shrouding, the core support was the same piece - in 58/9 on a V8 they supplied a shroud to make up for the length difference, rad stayed forward for both 6 and 8
but as longbox said, check a local rad shop, if the tanks are not rotten yours can be recored cheaper, much better choice if it's possible in your area
matt55 #958987 07/25/2013 9:49 PM
Sir Searchalot
Sir Searchalot
You may find what I found, nobody does recores anymore around here. They want to sell you a new one. All they know is plastic. No Solder Jockey's left. No downflow left.
matt55 #958992 07/25/2013 10:04 PM
Exactly what I found, they told me they don't recore those anymore.
matt55 #959061 07/26/2013 1:10 AM
Sir Searchalot
Sir Searchalot
Get the one on Ebay.
matt55 #959092 07/26/2013 8:14 AM
Same thing here in Northern Illinois, all of the old radiator
shops have closed up and any one calling them selves a radiator
shop just is an installer for new plastic or aluminum radiators.
I've used U.S. Radiator several times with good luck.
http://www.usradiator.com/chevrolet-truck-1955-59-all-mt-radiator.html
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
matt55 #959222 07/26/2013 9:38 PM
There's tons of those alum rad's on flea bay to fit almost anything. They are cheap and may or may not last long. Check Classic Parts and Jim's Carter's Truck Parts. They both sell brass/copper US made radiators but may well be back ordered.
FWIW, I'm going with an elec fan with a shroud which should help big time. That plus a new Rad should be good. I did find a shop in Auburn Ca that would recore for $500+... never mind...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
matt55 #959227 07/26/2013 9:55 PM
Thanks for all the advice, I really appreciate it.
Flxible #959576 07/28/2013 6:58 PM
not to highjack the thread, but are the big bolt radiators bigger? i know the whole front end is bigger but not sure about the radiator.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
matt55 #959588 07/28/2013 7:50 PM
the height/width wouldn't be different mater, but the thickness varied, there was a 'standard' radiator and a 'heavy duty'
matt55 #959591 07/28/2013 7:55 PM
so if i got a pickup radiator it would fit, but i would have to probably get a different fan shroud?
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
matt55 #959595 07/28/2013 7:59 PM
not necessarily, the shroud should fit, won't be a large difference in thickness, at most it will have a slight gap that could be easily dealt with by something like a fan spacer
matt55 #959775 07/29/2013 5:29 PM
alright, thanks for answering that, i passed up a recored radiator for 50 bucks this spring because i wasn't sure
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
