| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Didn't someone awhile ago post a list of all the nuts and bolts found on the 47-53 trucks? If so, could someone post a link. Thanks, MIke | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | bluedot38 - I don't think that any of us have found a list of "all the nuts and bolts" used in the construction of our trucks. You have probably discovered that the fastener part numbers in the FAM are often not the same as the part numbers in the MPC, however the MPC is often a good place to start. The best way to find info about a particular fastener is to post a question about the fastener or its use here on Stovebolt.com. Here is an updated list of sources ... > Stovebolt post (Nov, 2012)- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Thanks for the info, it's a starting point. was really interested in front motor mount hardware, bellhousing to frame hardware, and manifolds to block hard ware. Went through a can of old bolts and nuts, trying to figure out what was what. Know of a good source for oddball nuts and bolts nearby, will make a trip up there soon. Mike
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | bluedot38 - This is the info that you need for fasteners for your front mount ... I researched the fasteners for motor mounts on my '54. Should be the same as your '50 3104. I listed the GM part numbers and descriptions plus the closest available Fastenal part numbers and descriptions in a Stovebolt post. HOWEVER - I made a mistake in describing the location of the two thick washers on the front mount. The photo of the completed bolts, washers, & nuts on front mount in my post is also wrong. Denny Grahm desribes and provided photos of the correct location of the thick washers in his post in another thread. > FRONT MOUNT HARDWARE> DENNY GRAHAM'S DESCRIPTION & PICS OF THICK WASHERS- Lonnie
