3 members (Jay R, Rexville48, Hugh63c10), 84 guests, and 3 robots.
Topics128,050
Posts1,055,673
#958550 07/23/2013 8:56 PM
I am looking to replace the knee action shock with gas shocks, and I wanted to make sure I have all my ducks in a row.
This is on a '48 1 ton.
The replacement mounting bracket has four holes while the knee action has 2, do any of the holes line up? If not, what is the best method to make sure the top mounting bracket is in the right location?
What is the method for removing the the original knee action shock?
The top mounting bracket will only use three of the four holes and none will line up with the old shock mounting holes.
If you attach the lower mounts and tighten them the top will almost fall into place.
It would be nice if you had a 1950-54 truck next to you to see them mounted.
I could take some pictures of some installed if you would like.
My Blog
Pictures of the upper and lower mounts would be very helpful. Does the spring need to be compressed at all when setting the upper mount?
Thank you.
Thanks DADS50!
My Blog
Thank you for the pictures.
Once I tighten the lower mounts, that will give me the angle that I need to achieve. Is the upper bracket just centered on the frame at that angle? Is the spring under any type of compression at this stage, assuming the axle is not bearing any weight?
here is a better pic from Dennys web site, munus his sway bar bracket
...dennys pic...
His is a 3600
I have never done the conversion.
But the first pic I posted above the axel has no wieght on it.
It may not make that much difference but I would have weight on the axle if I was doing it.
My Blog
It looks like the bottom of the bracket is in line with the bottom of the frame... I will go with that and hope for the best.
The shock bushings are flexible enough that you will be fine.
My Blog
