| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Gave up the idea of an automatic with a PTO. New plan is to install a TH700-R4. The hydraulic lift will be run electrically and the winch will be electric.
Does anyone have experience mating this transmission to a 235?
Question is, will it bolt up to the '54 and after mounting plate for Hydro-matics? And is there a Hydro-Matic flywheel with a 6 volt ring gear (need to keep stomp starter) that will work?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jim Sears, the TH700-R4 for a V8 has the same bolt pattern as a lot of other V8 transmissions, Powerglide (aluminum case) 350, and 400 as well. Unfortunately none of these transmissions will bolt up to the 216/235/261 series of engines without an adapter (not the Hydramatic adapter). There is an adapter kit available from Buffalo Enterprises I believe, and possibly others. The kit includes an adapter and a special flywheel, unfortunately you must use a key activated starter, hope that helps. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks 3B I will check it out. Found a couple of "rat rods" with inline 6's and 700 trans, but no details on how they did it. | | | | | Joined: Jun 2013 Posts: 19 New Guy | | New Guy Joined: Jun 2013 Posts: 19 | Thanks 3B I will check it out. Found a couple of "rat rods" with inline 6's and 700 trans, but no details on how they did it. There probably using a 230,250 or 292 L6 from Chevy that will bolt up directly to any GM trans. for a adapter try this link from Langdon's 216 / 235 trans. adapter
