| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95870 06/08/2006 8:29 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | The shop manual for my 49 GMC 1/2T shows a special GM tool for pulling the upper steering column bearing that connects to the horn wire. The other end of the horn wire screws to the outside of the column. Does anybody sell or rent the special puller tool? Or is there another way to pull the bearing? Then what's a good way to get that wire back inside where it belongs?
Never start vast projects with half vast ideas.
#95872 06/09/2006 4:28 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | A screwdriver and small hammer should work if you tap evenly around the outside. Mine was tired and a puller would have only removed the inner race. It has a lip around the outside you should be able to get a screwdriver on. Tie or tape a wire to the end and when you pull it through attach the new wire and pull it back.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#95873 06/09/2006 8:16 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Those sound good. I thought about prying with a screwdriver. My usual tack. I'm glad to know it worked. If I screw up (1st time in my life, of course) I'll try the puller like 2many2 says. Same with snagging the wire before pulling it out. Thanks aplenty.
#95874 06/14/2006 12:07 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i used a screwdriver and just pried all the way round that bearing she came out easy. use a penetrating fluid
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95875 06/15/2006 12:09 AM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | It sounds better and better. I'll have a go this weekend. Thanks again.
