5 members (Gdads51, cmayna, JW51, BC59, Forty9), 108 guests, and 2 robots.
Topics128,092
Posts1,056,457
Members48,443
The shop manual for my 49 GMC 1/2T shows a special GM tool for pulling the upper steering column bearing that connects to the horn wire. The other end of the horn wire screws to the outside of the column.
Does anybody sell or rent the special puller tool? Or is there another way to pull the bearing?
Then what's a good way to get that wire back inside where it belongs?
Never start vast projects with half vast ideas.
A screwdriver and small hammer should work if you tap evenly around the outside. Mine was tired and a puller would have only removed the inner race. It has a lip around the outside you should be able to get a screwdriver on. Tie or tape a wire to the end and when you pull it through attach the new wire and pull it back.
You Tube
Those sound good. I thought about prying with a screwdriver. My usual tack. I'm glad to know it worked. If I screw up (1st time in my life, of course) I'll try the puller like 2many2 says. Same with snagging the wire before pulling it out. Thanks aplenty.
i used a screwdriver and just pried all the way round that bearing
she came out easy. use a penetrating fluid
Jim & Caroline
It sounds better and better. I'll have a go this weekend. Thanks again.
