| | | Forums66 Topics128,147 Posts1,056,798 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I'm trying to finish a 1950 Chevy 5 window cab pickup my friend and neighbor started on. He passed away in January and had bought some parts I'm not quite sure what to do with.
He bought kick panel covers to go inside over the kick panels. The passenger side cover is pretty straight forward, but the drivers side has the vent in the side of the kick panel with the lever and louvers on the inside.
Has anyone ever used these kick panel covers (cardboard) and if so, did you have to make cut outs in the cardboard for the lever and for the vent holes to match so air could flow in? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No kick panel covers on these trucks, that's a custom street rodder item. The only panel boards on these trucks were the half panels below the door windows, and the headliner.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | That's what I was thinking, but the owner of the truck wants them, so was hoping some one may have already performed this trick. | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | That cardboard is tough to cut and crumbles when you try to cut sharp turns. With the intricate cuts that you would have to make around the lever and louvers, I don't think if would look good even if you found a way to make perfect cuts. I believe these panels would be a better option on a 51 or newer truck, as they don't have the side cowl vent. Or you could make a cool louvered metal cover to put over the cardboard.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Think I'm gonna talk him out of this trick. Looks fine to me without them. Thanks | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If he insists on them, you could always cover then with a vinyl, which I've done in the past on cars that I re-upholstered the door panels on. That way you don't have to be so particular about what the panel board looks like after you cut it. DG
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | That's a good idea. And something I can do. We'll see. Thanks | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Roy,I made mine from 1/4" Ply,to transfer the pattern for the vents I used a piece of stiff paper cut to the same shape and used charcoal to 'brass rub' the pattern/vents onto the paper then transferred it to the ply. Plans are to cover it in leather when funds allow. Drivers kick panel. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
