3 members (55shaker, Jon G, BillCollins), 133 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#957974 07/21/2013 9:13 PM
Contemplating putting some 8.45 x 15 tires on 15 x 5 rims and need to know the installed tire section width. Don't have much clearance between rear springs and tire wall. Also is there any issue mounting that wide a tire on 5" rims? Thanks in advance for the info
The section width would be 8.45". Checking the spec guides, a 5.5" wheel would be better, 6" for best performance.
What year/size truck are they going on? It sounds odd to me that a tire that small would have clearance issues, as most GM trucks from the late 40s to '72 should be able to clear a 11.5" tire in the rear without issue, and I've even mounted some 12.5" tires on a few without rubbing.
Bill Burmeister
62401
Moderation Note: Ryanz had updated his post to say that these tires are bias ply. In the fog of war/moderation, the post got .. um ... deleted. No fault of his.
Sorry for any confusion. You may return to the discussion now ... blush
