| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Contemplating putting some 8.45 x 15 tires on 15 x 5 rims and need to know the installed tire section width. Don't have much clearance between rear springs and tire wall. Also is there any issue mounting that wide a tire on 5" rims? Thanks in advance for the info | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The section width would be 8.45". Checking the spec guides, a 5.5" wheel would be better, 6" for best performance. What year/size truck are they going on? It sounds odd to me that a tire that small would have clearance issues, as most GM trucks from the late 40s to '72 should be able to clear a 11.5" tire in the rear without issue, and I've even mounted some 12.5" tires on a few without rubbing.
Bill Burmeister | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Moderation Note: Ryanz had updated his post to say that these tires are bias ply. In the fog of war/moderation, the post got .. um ... deleted. No fault of his. Sorry for any confusion. You may return to the discussion now ... John | | |
