| | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | 460 e in a 1951 Chevy 3100. I am currently hooking up my shift linkage with the Lokar auto trans. kit. It was pretty simple, nut I have a question I can count 6 clicks from park. Drive,rev,nuetr,2,1,?. (Maybe low then 1 or 2 or something). My question is that my colmn. shift has only park,rev, nuetr,drive,2 & 1. It has only 5 gears besides park not six. Is this an issue? I don't have the drive shaft in yet. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If it's a 4L60E it's a 4-speed, so you'll have P,R,N,OD,D,2,1. There are no issue with your column only having the 6 total positions, as long as it stays in the gear you put it in. I have 2 vehicles that have transmissions with a different number of gears than the steering column originally had, and they work just fine. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | be sure to check the trans arm end compared to the shifter end and make sure the linkage is adjusted correctly from the park position and your neutral safety switch works as per Lokars instructions ... if it's an "E" what are you using for the computer? what column shift?
Bill | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think you can purchase a new gear indicator piece that mounts on your column, that shows correct gear ? | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Yes sir I looked it up thank you. If it's a 4L60E it's a 4-speed, so you'll have P,R,N,OD,D,2,1. There are no issue with your column only having the 6 total positions, as long as it stays in the gear you put it in. I have 2 vehicles that have transmissions with a different number of gears than the steering column originally had, and they work just fine. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Good that's what i wanted to know. If it's a 4L60E it's a 4-speed, so you'll have P,R,N,OD,D,2,1. There are no issue with your column only having the 6 total positions, as long as it stays in the gear you put it in. I have 2 vehicles that have transmissions with a different number of gears than the steering column originally had, and they work just fine. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Flaming river column, Don't have the computer or harness at this time. Any suggestions on the harness? be sure to check the trans arm end compared to the shifter end and make sure the linkage is adjusted correctly from the park position and your neutral safety switch works as per Lokars instructions ... if it's an "E" what are you using for the computer? what column shift?
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I believe all the stand alone computers come with the necessary wiring, I'm going with Optishift Quick 1 for my 4L80E, not the cheapest, but excellent warranty and features, including a selectable display that can show the gear selected, will do the 4L60 and the other members of the 'family' .... and FlamingRiver has an OD indicatorBill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Check what Painless makes as far as the harness goes. They make good stuff. | | | | | Joined: Oct 2012 Posts: 38 New Guy | | New Guy Joined: Oct 2012 Posts: 38 | Why Not go with a 700r4, rather than buying a comp to run the | | |
