4 members (Steelonsteel, texas46, Ponchogl, Bill Hanlon), 65 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#957885 07/21/2013 3:42 PM
460 e in a 1951 Chevy 3100. I am currently hooking up my shift linkage with the Lokar auto trans. kit. It was pretty simple, nut I have a question I can count 6 clicks from park. Drive,rev,nuetr,2,1,?. (Maybe low then 1 or 2 or something). My question is that my colmn. shift has only park,rev, nuetr,drive,2 & 1. It has only 5 gears besides park not six. Is this an issue? I don't have the drive shaft in yet.
If it's a 4L60E it's a 4-speed, so you'll have P,R,N,OD,D,2,1. There are no issue with your column only having the 6 total positions, as long as it stays in the gear you put it in. I have 2 vehicles that have transmissions with a different number of gears than the steering column originally had, and they work just fine.
My 46 GMC on Photobucket
be sure to check the trans arm end compared to the shifter end and make sure the linkage is adjusted correctly from the park position and your neutral safety switch works as per Lokars instructions ... if it's an "E" what are you using for the computer? what column shift?
I think you can purchase a new gear indicator piece that mounts on your column, that shows correct gear ?
1940 Chevy KC 1/2-Ton
46gmcpu #958291 07/22/2013 9:40 PM
Yes sir I looked it up thank you.
46gmcpu #958292 07/22/2013 9:41 PM
Good that's what i wanted to know.
Flxible #958293 07/22/2013 9:42 PM
Flaming river column, Don't have the computer or harness at this time. Any suggestions on the harness?
I believe all the stand alone computers come with the necessary wiring, I'm going with Optishift Quick 1 for my 4L80E, not the cheapest, but excellent warranty and features, including a selectable display that can show the gear selected, will do the 4L60 and the other members of the 'family' .... and FlamingRiver has an OD indicator
Check what Painless makes as far as the harness goes. They make good stuff.
Why Not go with a 700r4, rather than buying a comp to run the
