| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | You're link is not working, at least not for me.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I can't view the link right now, but I can say that a lot of the LED replacement bulbs are way too dim and aren't any brighter than the bulbs they're replacing. The best are the ones where there is a board of lights meant to fit in a specific light. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I purchased a set of these for the front ...pic... Have not used them yet but did test them and they are bright. for the rears I'm using the 45 LED lenses and they are great. the price is not to bad on those Amazon bulbs, If you get them let us know how they work out. | | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | In order to achieve maximum led output you would install an amber led light behind an amber lens. Red behind red. Been there done that.
I know there may be some disagreement but I respect everyone's God given right to be wrong.
Don 1950 Chevy Panel Delivery. Purchased in 2008 that was in a family for 35 years. Restomodded in 2006.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If they're the style I think they are, you may need to modify the housing to make them fit. Seems that they will not go deep enough into the socket, as the led housing contacts the lamp base. Easy alteration if you're handy with a Dremel tool.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
