10 members (Bill Hanlon, Otto Skorzeny, BarryP, mick53, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, 1 invisible),
113
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | 0316646T54X
Its off a 54' 3100 (not that its an original motor... i dont know)
I cant tell what the actual block numbers are cause its under crud and behind the starter, and I THINK I found some information using the serial number, but then I also found information that didn't support that. So I want help from you experts out there!
Thanks!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1954 truck serial number info T = Tonawanda plant 1954 = model year X = 3100 series truck (1/2 ton) | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | and the number before the T54X just a unit number?
That's what I thought, but then somewhere else it said a 1960 Suburban (hence the conflicting info and why I posted).
Thanks! | | |
