0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
0316646T54X
Its off a 54' 3100 (not that its an original motor... i dont know)
I cant tell what the actual block numbers are cause its under crud and behind the starter, and I THINK I found some information using the serial number, but then I also found information that didn't support that. So I want help from you experts out there!
Thanks!
1954 truck serial number info
T = Tonawanda plant
1954 = model year
X = 3100 series truck (1/2 ton)
and the number before the T54X just a unit number?
That's what I thought, but then somewhere else it said a 1960 Suburban (hence the conflicting info and why I posted).
Thanks!
