BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (greenie-reddy, Deegs53, Cosmo, Otto Skorzeny, TooMany2count, DennisM, 1 invisible),
540
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,297 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi - I'm just about to fire up the truck.I have bought and rebuilt a delco 948r generator with cut out and put a new harness in the truck. I just wanted to ask a few questions before i hook up the battery. 1) The harness instructions are telling me to ground the field terminal on the generator to the generator frame if I don't have a resistor on my headlight switch (which I don't). I wanted to make sure this is correct. From my reading of wartime delco repair manuals it seems this model is externally grounded and thus needs the ground to frame. The harness instructions left out a coil to ignition switch wire so I'm a little concerned about their accuracy.
2) to polarize this generator all I have to do is hook up battery to system, then use a jumper wire to bypass the cutout without the engine on?
