5 members (Forty9, dt235sd, FAST55, Otto Skorzeny, 1 invisible), 81 guests, and 1 robot.
Topics128,050
Posts1,055,754
#957716 07/20/2013 7:07 PM
My 1949 GMC is quickly looking like it will become a period correct fun street machine - a good running 270 with eye candy. Seeking your input on other considerations. New dome top pistons – 10:1 same rods - ordered Dual carb intake & dual period correct Zenith carbs – have it 6v Pertronix ignition - installed Split headers – have it Full flow oil system with screw-on oil filter Timing cover trick Performance cam – have it Adv / Dur: 298 / 298 .050 Dur: 228 / 228 Cam Lift: .297 / .297 Valve Lift: .490 / .490 Centerline: 106 / 114 Mild porting to existing head (small port) Rebuild head to original specs Electric fuel pump? – your thoughts? Overbore to get 292? – your thoughts? Larger Exhaust Valves in stock head? Drive train will remain stock. Anything else I should do to warm up the engine?
Be the person you would want as a friend because at the end of the game the King and Pawn go in the same box.
Not sure why my details are not showing up.
Finally got it to post my typing.
Sounds good to me. Where did you get the carbs?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
