1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I pulled out the 4 wood window trim frames today getting them ready to finish and install after the new glass and channels are secured in place.
Can anyone confirm that these frames were the same hammered bronze color as the dashboard.
Currently I have just coated them with epoxy to seal them from the elements.
Thank you, Dave Murray | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have 46 of the 41 to 46 time frame. It has no wood in the windows. Your truck must be older? Are your head lights on the fenders or off the radiator frame. | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hello DAve, For what it's worth, the wood frames on both of mine were painted with the same color as the dash. I should say what paint was left on them.
Patrick
Richard J Patrick - 1946 Suburban
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | To answer GWWirth question, my Suburban is a 1946 for sure. The frames around the front doors are just like a pick up, metal.
The 4 windows (2 on each side) have wood frames that I would hate to pay to reproduce.
Thanks Patrick you have confirmed my suspicions.. Dave Murray | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | |
