2 members (Chip O, Gdads51),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95768 06/01/2006 12:27 AM | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | I got a real simple one. My 51 Chevy truck still has original 6V system. Can I jump it with my 12v car? Thanks. | | |
#95769 06/01/2006 12:47 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My neighbor jumps his 6V tractor with 12V all the time. Just don't crank it for a long time or you'll fry the starter. Oh yes, don't turn anything on but the ignition switch.
#95770 06/01/2006 12:50 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It can be done, but I would not reccomend it. If you do try it, connect the positive to the battery and the negative to a good engine ground, NOT TO THE NEGATIVE ON THE BATTERY. I've seen batteries explode from this. I've also seen a starter catch on fire and a 6 volt coil explode from too much voltage. Granted the situation was exsessive, the guy was trying to use 48 volts to start a 6 volt positive ground '29 Buick. Your best bet would be to use a 6 volt charger/booster to start your truck.
Bill Burmeister | | |
#95771 06/01/2006 12:52 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | You may stand a good chance of smoking your gas gauge. Also don't leave the 12 volt car running you also stand a good chance of popping the 6 volt battery. | | |
#95772 06/01/2006 6:05 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You'd be better off taking the 6v battery out and getting it charged for free at a place like Autozone or another FLAPS where they will charge it and test it. IF it needs to be jumped frequently, there is a problem somewhere that needs to be fixed.
#95773 06/01/2006 7:22 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't claim to be an expert at 6V to 12V conversions. I did one conversion on my old 55 1st panel though. For the conversion I changed the coil, voltage regulator, generator and bulbs period. I didn't add a resistor or anything else to drop the voltage to the guages. All of the guages ran with 12 volts with absolutely no problems and I put over 100K on the truck after the conversion. I don't think you'll have any problem with your guages but I still wouldn't turn your lights or any accessories on while the 12V battery is hooked up to it. A lot of folks here strongly advise dropping the voltage to your gauges & while it certainly can't hurt I've personally not seen a probem with not doing it.
#95774 06/01/2006 10:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a helper have them make the final connection right before you engauge the starter. Than remove it as soon as it starts. Make the final connection on a ground away from a battery like Longbox says. Like nm51 says you should fix it so you don,t have to jump start it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95775 06/01/2006 10:58 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I always just put a battery charger on mine and let it sit for an hour or so.
Of course, I've got mine working right and I rarely -- if ever -- need to do that any more. | | |
#95776 06/02/2006 12:10 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | When/if you find yourself in a situation that you need to jump start a 6v system from a 12v system, Wrenchbender Ret.'s technique works very well and it is safe. | | |
#95777 06/12/2006 8:28 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Originally posted by Tiny: I don't claim to be an expert at 6V to 12V conversions. I did one conversion on my old 55 1st panel though. For the conversion I changed the coil, voltage regulator, generator and bulbs period. I didn't add a resistor or anything else to drop the voltage to the guages. All of the guages ran with 12 volts with absolutely no problems and I put over 100K on the truck after the conversion. I don't think you'll have any problem with your guages but I still wouldn't turn your lights or any accessories on while the 12V battery is hooked up to it. A lot of folks here strongly advise dropping the voltage to your gauges & while it certainly can't hurt I've personally not seen a probem with not doing it. I haven't looked at a 55 for a few, but all but the gas gauge don't use electrical senders? 12V should be ok on the amp meter. It's a mater of how full the gas tank is as to excess voltage to that guage.
"It ain't a truck if you can't hose out the cab."
#95778 06/13/2006 8:44 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | we used to keep a 12 volt on the floor of a old chevy work truck when it wouldnt start on 6 it would always start on 12 never hurt anything just unhook the 12 when it starts | | |
#95779 06/20/2006 5:33 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Hey, I ran across a guy that has found 6V optima batterys. They have twice the cranking amps of a standard 6V battery and are only 1/2 the size. Your parts store I am told will tell you optima dosn't make a 6V battery, but your battery supply will have Or can get one. They are jell cell and you can mount them up side down and they wont leak. But on jumping a 6V with a 12V that should be left to a professional. Or go buy some realy cheap aluminum jumper cables, I think they only let about 9 volts through. lol (that was a joke)
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
