1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | hey, i just found out i have a 1959 261 with 235 heads which i thought was a 235 as i was told when i bought the truck. anyways im in the process of installing an hei dizzy i got from langdons and it tells me to rotate the engine to 10-18 degrees before top dead center, the tdc mark on the flywheel is a indented circle, right before the circle there are two lines an inch or so apart, a couple inches before the lines there is a triangle. where exactly is 10-18 degrees btdc? and what are these other marks? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I looked in my '59 shop manual and can't find any reference to all those timing marks. The ball is considered TDC, but even that may have the distributor firing at 4 degrees BTDC. Not much help. I would think Langdon could help you out on timing. Give him a call.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | I was thinking that the circle is where the ball used to be, and it was somehow taken off. How shall I time it after I install the distributor | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Also, a dwell meter may help getting the timing right.
Drew
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | FWIW, If you are unsure of the marks, You can always put a piston TDC stop in the #1 hole as well. With #1 coming up on the compression stroke but still at the bottom of the stroke install the stop and by hand bring up piston till it just touches the stop. Mark the Fly wheel where the pointer sits. Then by hand reverse the rotation until the piston just touches again. Mark this and 1/2 way between the two marks it true TDC.
