| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Been fixing up the 50 Chevy 3100 and working on issues as I find them. When I run the engine, it appears that the ammeter is not moving. I looked at the generator, but couldn't figure out which terminal is Field and which is Armature. Looking from the front of the generator, there are to terminals. The only markings are two triangles. One by each terminal. One points to the front of the generator and the other points to the back. I saw a general statement online that said "when looking from the front, the Field terminal is on the right". As for the generator, it's a Delco Remy 1102711, which was cataloged for a 49/50 Pontiac. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | is it hooked up? you regulator should be marked B - A - F .... are you sure the gauge is good? have you used a multimeter on the battery to see if it's being charged while the engine is running?
Bill | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Yes, the battery is getting a charge. My main question was how to tell which generator terminal is which. They're not marked A or F. As I mentioned in my post, there are two stamped triangles, one by each terminal. One faces towards the front (pulley) and the other faces towards the rear (firewall). I wish they had marked them A and F. One person said tou look at the terminals from the front of the engine and the Field is on the right. But someone else said you look from the back, so now the Field is on the right. Confusing!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the generator is hooked up and working, then you should have the markings on the regulator it's hooked to, to tell A from F, just follow the wires Bill | | |
