1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95749 05/30/2006 4:49 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I pulled the original steering column from my 61 Chevy Pickup and am replacing with a tilt column from a 67-72. I am not sure I have the wiring connected correctly.
Does anyone have any experience with this?
Thanks. | | |
#95750 05/30/2006 10:13 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It should,t be too much problem. You could get wireing diagrams for both models or trace the wires. The 67-72 connector is better. A wire off the stop light switch goes to the turn switch & connects to the rear stop/turn lights. The front turns go to the front lights & dash ind. lights. If you have a specific problem discribe it & we,ll try to help. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95751 05/30/2006 10:26 PM | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have a '68 tilt column in my truck. Should have ( 8 ) wires in harness. Black=horn, Lt. Blue=LF turn signal, Dk. Blue=RF turn signal, Brown=Hazard Flasher, Purple=Turn Flasher, Yellow=LR Turn signal, Green=RR Turn signal, White=Stop light switch. There may also be an additional wire to the small light bulb at the shift indicator. | | |
#95752 05/31/2006 1:36 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Wrenchbender,
Please explain this statement a little further for me.
---A wire off the stop light switch goes to the turn switch & connects to the rear stop/turn lights.----
Thanks | | |
#95753 05/31/2006 1:39 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Wrenchbender,
Do you know where I could find a wiring diagram for the 61?
I've got the diagram for the 67-72.
Is it as simple as matching color for color from both? (Did GM use the same color codes?)
Thanks | | |
#95754 05/31/2006 1:42 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | britcon,
Thank you. This is very helpful and further clarifies info I started to figure out from the wiring diagram I have.
Thanks | | |
#95755 05/31/2006 10:36 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Britcon shows this as the white wire. When the turn switch is not on & the brakes are applied curent from the stop light switch goes through the turn switch to both stop/turn lights. When the turn signal is turned on it interrups & flashes the coresponding light. Understanding this helps diagnose the problem. I believe the colors are the same. I,ll look tomorrow when I,m at the shop. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95756 06/01/2006 4:01 AM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Wrenchbender,
Thanks for the explanation.
Here is what I understand that I need to do.
My stop lamp/light switch has two wires running to it from the wiring harnass. One is white and one is orange.
I will need to split a new wire from the white wire and run it to the white wire going into the 67-72 column wiring. Right?
Please let me know if I understood this correctly.
Thanks | | |
#95757 06/01/2006 4:08 AM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Britcon and Wrenchbender,
Also there is a gray wire that is a lone wire coming from the 67-72 steering column. Where does this wire go? What does it do?
thanks | | |
#95758 06/02/2006 9:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m not shure what you mean but the white wire needs to go from the stop light switch to the turn switch. The late model connector is the best. The grey wire is for the light in the shift ind. There might be a place in the fuse box to plug it in or wire it to one of the dash lights. It should dim when you turn the knob on the headlight switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
