1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I am mating a Chevy 350 with a Muncie SM420 transmission. The bell housing is the stock unit for my 59 3100.
Which flywheel and starter should I use for this application?
thanks
Is rust considered a body style?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the transmission has nothing to do with the starter, use the 59 flywheel and starter, providing the bellhouse is from a V8 [59 283?] and the starter too, with the key start solenoid
Bill | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I was hoping for something a little more specific.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy arturo7, the only thing I would add to what red58 has said is if the engine is a 1986 or newer engine (one piece rear main seal), it will require a flywheel the same diameter as the 265/283 original flywheel to match up with the starter, if the engine has a two piece rear main seal you could use the stock 265/283 flywheel, hope that helps. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Art You should use a 168 tooth flywheel that is drilled for an 11" clutch for the crate engine. I thought you got the starter from Mike, if not you need the 3 hole horizontal mount end plate to match the bell housing. Call me, we need to get it fired up. Fred
