3 members (WICruiser, kades51, 1 invisible),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Ok guys, one more question: I fillet my radiator up with AF yesterday and when I took a look at it this morning I had a very slow drip. After chasing it down I found that the AF is coming out of a bolt hole on the block low on the driver side rear of the engine (straight down from the no. 6 exhaust port). The hole is threaded, but I don't recall taking anything out of that hole.
I suppose I should tell you that its a 1959 235. Anyone have any idea what is supposed to be there? Or is it more likely that I have a crack or something? I'll post a pic as soon as I can. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | that's the water drain plug. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | you guys are magnificent! I was hoping it was something that simple. I'm on my way to the auto parts store for a petcock! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If it was mine I would plug it with a pipe plug. A valve, as shown, can leak.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On the four trucks that I have worked on in the past 16 years, the radiator draincock is, I think, the same draincock that is used on the side of the block. None of them leak. | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Got the radiator draincock in there, now to see if that sews up the leak. I sure hope that's it, I hate to think about tearing that thing down again.
Thanks for the quick turn-around guys, this forum is the best! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Notice it was a slow drip. None of my sixes ever drained well from that hole. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Notice it was a slow drip. None of my sixes ever drained well from that hole. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | after i get mine flowing real good i put a ball valve on and plug the valve. when i need to drain it i screw in a ell and a long nipple and drain it right into a bucket no fuss, no muss and no mess. once a year i drain about a gallon of fluid out of it. if its all good and clean i just dump it back in the rad. its not original looking but its more functional that what came from the factory. here's the set up when the 228 was still in. http://s1301.photobucket.com/user/B...mp;_suid=1374230892302030849790071747757 | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | that is what I did, (the ball valve) One added benefit would be that you can jam something through the valve to clear out the hole if need be, and then be able to shut if off. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If you only have a small drip coming from where a drain cock should be, you have a lot of crud in the water jacket. While I would like to recommend that you get all the crud out of your water jacket, it is much easier said than done. The only way that I have been able to accomplish total clean out was by removing all of the freeze plugs including the ones in the front and rear and flushing it out with a hot pressure washer blowing through every coolant hole in the block including the ones under the head. It was also necessary to stand the block on end and then on the side to get everything out.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Like I said, a pipe plug is best. It only has one way to leak and a drain cock has several ways to leak/corrode. The pipe plug can be purchased with a hex head so easy to remove with a socket for FULL hole drain, not a small drain cock hole. Why a drain cock, to be "pure"? If you use Antifreeze and distilled water, why all this draining?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | From this man's description, his drain cock was completely missing and was just barely dripping! My guess is, someone in the past did not follow your suggestion of anti-freeze and distilled water and now may have a seriously plugged up water jacket. I unknowingly had this same problem on my first 216. When my original brass t-stat stuck closed one day and overheated, my water jacket cracked right at the top of where the crud in the water jacket leveled off. Coincidence, maybe.
