| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hi all! I'm re-powering my '38 1 1/2 ton dump with a 1962 235. I want to keep my 'stomp start'. Looking around this site, and my engines, I think I need a flywheel with a 139 tooth ring gear, 9 bolt 10 3/4" clutch, and six bolt crank mounting holes. Being as this is the first big bolt I've worked on, can you guys get me pointed in the right direction? Where can I find this critter, if it exists?
Tom | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Place a Parts Wanted ad in the Swap Meet.
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Yep, they exist. I use one on my 39 3/4 ton with 235. I found it in a local yard in the remains of what was probably a 1948 3/4 or 1 ton. Should be fairly common and will show up in the swap meet. | | |
