Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Wally / Montana, Tyler Watts, 2 invisible), 139 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
#957014 07/17/2013 12:29 PM
Finally got my 1955 1st Series 6400 with a 261 back on the road. Starts great, runs great with no hiccups or pops. When I come to a long grade, not really steep just long, I expect it to slow down but with the peddle smashed to the floor I continue to loose speed just to the point of having to down shift but not quite. Any thoughts on what might be the issue? Timing, carb, something else? I haven't checked the compression yet but did have a friend adjust the timing last fall. Any help or further questions would be fantastic.
Bruce
My Trucks
Stuff I Collect
issue? I'd say you're learning what it was like for truckers back in the day wink in a 1.5T truck when you'd see a grade ahead you mash the pedal well before you start the climb, and if you were loaded you'd be down shifting before the top even if you were speeding at the bottom
Flxible #957031 07/17/2013 2:04 PM
I'm familiar with the "take a run at the hill" syndrome but this slows down really fast, faster than other trucks I've driven. At close to 60+ heading up the grade, I'd be at 20 very shortly with no load other than my gut! This should be a torque monster (for the day) with the 261. I'm going to borrow a compression tester from a friend and see what I'm at per cylinder. Something just doesn't seem right.
Bruce
My Trucks
Stuff I Collect
It could be the timing. I had a similar thing happen, and that's what it was. Good luck.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I would also start with timing.
With today's gas these engines like a little more advance than called for.
My Blog
Riding in the Passing Lane
I would start with the timing also. The 261 &292 use a carb with a larger bore. Often when someone exchanges it for a "rebuilt" carb they wind up with one from a 235. That will cut the power down. It might be jetted too lean.
1972 Chevy c10 Cheyenne Super
Good point about the carb size.
My Blog
Good point on the carb but it is the correct one for a 261. I have a stash of 261 carbs just in case. I don't have a timing light or vacuum gauge but I know people who do. I'll probably start there.
Bruce
My Trucks
Stuff I Collect
