1 members (dunfire), 157 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
My 1946 Burb has 4 side windows with no metal trim like the cab doors have.
I need to shave the glass about 1/16 to 1/8 inch in order for it to move smoothly up and down in the new window channels and wood frames.
Can anybody suggest a process to do it? I am thinking using a belt sander with a fine sanding belt.
Am I on the right track? The amount I need to remove is too small to use a glass cutter.
Any help or suggestions are appreciated.
a wet belt sander or go to an old glass shop and have them do it on theirs
Out of curiosity, why a wet one?
Thank you!
because it is so hard glass is only sanded wet, lubes the cut and prevents heating and chipping ... use carborundum closed coat wet n dry paper [or a diamond grit wheel]
