| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | I have a customers 1946 Chevrolet Truck in my shop and it is missing the piece that holds the front Hood hinge rod and bolts to the top of the upper grill pan. I guess it would be the front hood mounting bracket? I need to help this guy out and see if I can find one but Im not sure what to call it? Thanks for any direction or help.
Change is Opportunity
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You maybe referring to the "Bull Nose" To be sure post a picture. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | If it is the bull nose that fits between the front hood halves and is held on with two bolts on top of the radiator support and two more bolts at the front on top of the grille I have 1 in good shape. Dave Murray [email protected] | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | One other point. Make sure there is a 1 inch protrusion from the front of the hinge for it to fit into the "bull nose" or you will need a new hinge as well. | | |
