2 members (Hotrod Lincoln, 1 invisible), 112 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
Page 2 of 2 1 2
Taylorcraft1 I have Pm'd you and emailed some questions but have not heard back from you. Please check through your emails for mine. Also, I have talked to Webster, I am not sure he really did have one. Thank you!
if you drill it for full pressure oiling and use GMC rods, you should be fine, That is one of my upcoming projects. You wouldn't have to turn it over about 4500 to get good power.
Just because you can doesn't mean you should, BUT, if that's what you want to do, make sure you take a video when you wind that sucker out. I wanna see it!
Frankly though, It doesn't make any sense to me. I guess I kind of like era correct stuff and a turbo doesn't go with a 216 in my head.
If you were using a modern turbo system, stay with a more modern motor. Why would anyone choose an antiquated motor that has so many limitations?
Even if you had an era correct vintage turbo system (if such a thing exists), the 216 sure wouldn't have been the motor of choice back in the day.
It all seems incongruous and kind of a "unusual" exercise. I get it that some folks like to be unusual, which to me is okay if it makes sense. Otherwise it just seems kind of silly.
Now a 302 GMC with a Supercharger might be cool as hell, would stay together if built right, has a "wow!" factor (instead of a "huh?" factor) and will net you some serious speed.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
this whole hobby doesn't make any sense.
Don't know if a babbitt bearing 216 could take it. Maybe if she were line bored and insert bearing installed. Another issue is oiling. Don't know if a 216 could feed enough oil. A ball bearing turbo would be best. Maybe even a belt drive oil pump.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
notice I said drill for oil, and use GMC rods, of course you would use insert bearings. You wouldn't use a stock 216 oil pump, you would use a GMC oil pump. There would be very little stock for that matter. I'm not sure of the current state of development of turbos, but I don't think they use ball bearings any more. The fella at Ross pistons said that turbocharging inline 6's are actually pretty popular due to the fact that the breathing of the heads on most inlines quite frankly sucks. You don't just throw a turbo on pretty much any engine without a fair amount of modification. This is one of my really favorite things to think about, after the 12 port of course.
Why on earth would anyone want to s.charge a 216? I doubt it would get more than 30 yards down the strip before those bearings would need to be swept up off the pavement.
My deductions: 1) you want speed 2) you don't care about original.
3) you prefer an inline six
Why not use a more compatible six which also comes with more torque?
~Jim
the same reason people watch football, play golf, or ride horses. None of which makes a lick of sense to me. And other than the watching football part, cost just about as much. But since I absolutely abhor football. I would rather turbocharge a 216. Why would you assume it is going to the dragstrip? It is just an activity. Wouldn't give it over about 3-4 psi boost, just about like the Chrysler K cars. You wouldn't have to turn it over about 4000 RPM, a turbo isn't speed dependent, it is load dependent. Doesn't cost nearly as much as a motorcycle, or a boat, or a motor home. And I would much rather have a turbocharged 216, pretty much guarantee no one else will have one. You don't have to deduce anything, and you are wrong on most counts. I just want to do it. After I get the 12 port running of course. Unless I find a good deal on an offenhauser 270 to put in a T-bucket.
Sounds like fun, go for it.
~Jim
Moderated
Moderated
Do it to it!
Garrett's page on ball bearing vs. journal bearing turbos
http://www.turbobygarrett.com/turbobygarrett/journal_bearings_vs_ball_bearings
"The Fake Truck"
Ah yes, I wasn't sure of all that. However I did find a 1926 miller straight eight for sale. Not sure how much it would be, probably more than my house.
yep, it would cost about as much as my house....
Moderated
Moderated
if supercharger could be of interest, the Eatons are internally lubed without pressured external oil. Then the low splash oilpressure trouble on the 216 , want be any trouble.....
you wouldn't use a stock 216 oiling system, just like you wouldn't use a stock 216 oiling system for any other modified 216.
Page 2 of 2 1 2
