| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | I bought a '53 3/4 ton front and rear axle, but they are in pieces. Does anyone have pictures, or a shop manual to show how this is supposed to go together? | | | | | Joined: Jun 2013 Posts: 16 New Guy | | New Guy Joined: Jun 2013 Posts: 16 | Have you been here: http://chevy.oldcarmanualproject.com/I will have my 3/4 brakes apart on the chassis I just got (it's a 3/4 ton). I'll take pictures, but I don't know how soon I'll be at it. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i redid my 53 3/4ton front and rear brakes. they are the bendix type. i used the 54 manual. if you've ever done drum brakes before they are pretty much the same. the springs are a bit of a pain.
rolf
1963 c10 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | Thanks to the help everyone! I have the front back together and adjusted. Hopefully they work better then new! Now I just have to install the axle, upgrade the tie rod ends, find a sway bar, replace/upgrade (undecided) the master cylinder and be back on the road! Maybe if I meditate enough I can figure out a disc brake conversion for the original front axle... | | |
