8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
#956055 07/12/2013 11:14 PM
I bought a '53 3/4 ton front and rear axle, but they are in pieces. Does anyone have pictures, or a shop manual to show how this is supposed to go together?
Have you been here: http://chevy.oldcarmanualproject.com/
I will have my 3/4 brakes apart on the chassis I just got (it's a 3/4 ton). I'll take pictures, but I don't know how soon I'll be at it.
1949 3/4 Chevrolet Pickup
Odenville, AL
www.sterlingironworks.webs.com
i redid my 53 3/4ton front and rear brakes.
they are the bendix type.
i used the 54 manual.
if you've ever done drum brakes before they are pretty much the same.
the springs are a bit of a pain.
rolf
1963 c10
Thanks to the help everyone! I have the front back together and adjusted. Hopefully they work better then new! Now I just have to install the axle, upgrade the tie rod ends, find a sway bar, replace/upgrade (undecided) the master cylinder and be back on the road! Maybe if I meditate enough I can figure out a disc brake conversion for the original front axle...
