3 members (baldeagle, 2 invisible), 88 guests, and 4 robots.
Topics128,018
Posts1,055,340
Members48,419
#956186 07/13/2013 5:04 PM
I have a 58 apache half ton. Did the bed mounting bolts go through wood blocks for spacers or did they go through rubber pads?
6571 #956188 07/13/2013 5:11 PM
none of the above, but I think most would use a thin piece of rubber to avoid any squeaks if bolts loosen a bit as the wood shrinks
Flxible #956189 07/13/2013 5:41 PM
I used some 4x4 inch by half inch rubber pads on mine. Someone had turned it into a flat bed.When I bought the truck the guy gave me a 55 GMC step bed , so I guessed at the mounting .
6571 #956199 07/13/2013 6:24 PM
that'll work fine
