7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible), 90 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#956124 07/13/2013 11:02 AM
ok, drained my 4 speed transmission today. It is bolted to a 235 Chevy. Oil was thick and black. it was above the fill plug on the side. I pulled the side cover of since I could not remove the drain plug. Refilled through side plug with 80w90 gear oil. Want to make sure I'm not missing something. Is there any way to figure out what transmission I have?
Post a side-view photo of it.
Post any codes/numbers that are on it.
What model is your vehicle is it 3 or 4 spd etc, synchromesh or not
Dose it have the park brake mounted on the rear of trans
