5 members (32Fordpuchoptop, treegrower, Jon G, Danielbolt, 1 invisible), 194 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#955978 07/12/2013 11:25 AM
I'm wanna try to set the toe in on my '54 3600. Can anyone tell me the factory measurements / specs? THANKS!
The specificatons are given in the Shop Manual: 3600 toe-in 1/6"-3/16" (so, set at 1/8")
Thank you sir!
How are you planning to do it? Theres a few good methods.
I think using a pin stuck in the tire tread would get you the closest. I've seen a youtube video showing a string down the side parallel to centerline.
Are you running bias or radial tires? If you have original style bias ply, set it at 1/8" as the manual states. With modern radials, set it at 1/16", as radials can get away with less toe in.
Bill Burmeister
